Dot on new tire lightest spot?
rjk40
Post by rjk40 »
Maybe I am missing something, but I have seen on some videos that a new tire will have a dot on it to show the lightest part of the tire, which should be placed at the valve hole in the rim; I have new Avon Roadmasters, but do not see any dot. I am guessing that, since there is no dot, the rotational placement on the rim is not important.
Any comments are welcome.
Thanks in advance.
Richard
Gardner
Re: Dot on new tire lightest spot?
Post by Gardner »
Never seen a dot on a Avon Roadrider, and I've put a lot of them on. Balancing has always been pretty easy.
Go for it!
1978 SD Darmah
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
Paso 750
Many - most? - tires these days don't have a dot, Richard. As per Gardner, just balance carefully after fitting.
rjk40
Post by rjk40 »
Thank you, Gentlemen,
You have confirmed my deductions.
Richard
gt94stang
Post by gt94stang »
I just mounted new tires on my 750 GT and they had dots. Yes, you mount the dots are the valve stem.
