spark plug caps!
spark plug caps!
What are folks using for bevel twins? One of my original 81 MHR ones has a broken wire coil, the bit that the plug top pushes into, and a new one costs over US$50. There's got to be a better way. NGKs?
Cagiva Gran Canyon
Re: spark plug caps!
Yes (to NGKs, that is ...). It's what I use on my Dramah and my Laverda.
You need to check whether you need resistor caps or not. I think the MHR came with both at different times?
Look at the range you have to chose from! :-D
http://www.ngksparkplugs.co.za/products ... stor-caps/
I ended up ordering a pair of NGKLB05F caps and was impressed; each cap has two waterproof boots, one for the HT cable and one for the plug.
