Sidestand hitting header
OZHoppo
Post by OZHoppo »
Gurus,
I am rebuilding an 82 Darmah which has a Staintune exhaust fitted.
The header hits the side stand pivot point and won't retract fully.
Is there a difference in header pipes between SS and Darmah?
Steve
Re: Sidestand hitting header
yes, but, you said you have a Staintune exhaust fitted..........
Have you already tried loosening everything up on your exhaust and moving the header to get clearance and then tighten everything back up?
OZHoppo
Post by OZHoppo »
Yep, tried that but will go back and start again. I could very well be doing something silly
OZHoppo
Post by OZHoppo »
Problem solved kinda.
I took the exhaust assembly apart to start again and noticed that it has S2 stamped on the pipes. I am guessing that the S2 system is just slightly different from the Darmah.
