G'Day Steve,
Quite some time ago I installed the kit you supplied.
I am have just blown a fork seal so plan to disassemble clean etc.
When I first installed the spring kit i discarded the spring tube part # 0795.37.340.
I have spent ages reviewing the chassis and suspension forum but can find no reference to this.
Was I correct in discarding this bit
The ones I removed look much longer than the pics of the ones with that part # in your shop
thanks
garryc
works performance spring kit
Re: works performance spring kit
yes that shroud thing is no longer needed with our correctly sized spring kit....
