Darmah FPS wheel bearing installation
NeilD
Post by NeilD »
can't find a thread but apologies if already covered.. :oops:
specifically regarding the rear wheel... bearings were removed by the guy who painted them, so i'm not quite sure how they go back together...
from pictures i have, looks like the longer end of the stepped down portion of the spacer (ie part that protrudes through the bearing) goes on the caliper side of the wheel.. ? question is, whats the best procedure for fitting the bearings and spacer? should i fit the spacer to one of the bearings on the bench?
I'm used to wheels where the spacer just fits between the bearings rather than be located in/through the inner race...
4 bolt wheels if that makes any difference..
thanks.
drikko
Re: Darmah FPS wheel bearing installation
Post by drikko »
I'm desperately trying to get the same collection of bits apart! None of it will budge........gggrrrrrr
Cagiva Gran Canyon
drikko wrote:I'm desperately trying to get the same collection of bits apart! None of it will budge........gggrrrrrr
See my reply on t'other thread, drikko.
viewtopic.php?f=21&t=1060
