early narrowcase 250 segment locking plate needed
ajleone
Post by ajleone »
Anybody out there have a "segment locking plate" part number # 0603.07.170 for a very early 250 engine ? I need one.
This part is for the 12.5mm diameter kicker shaft. There are larger shafts used in the later model years, which does not help me.
Here is the parts diagram:
Any leads would be appriciated !! Thanks.
Tony
70 450 Jupiter (Scrambler)
74 450 MK3
61 250 Diana (project)
66 250 Mark 3 (project)
66, 67 250 Scrambler
65 125 Bronco
76 Vespa Ciao (my daughter's)
GT Pete
Post by GT Pete »
Hi Tony,
Have you checked with Syd's Cycles?
Chris Bushell
Post by Chris Bushell »
Part no 170 is not fitted to any of my 4 speed engines, I think that you will find that is out of the 5 speed later engine.
I just checked the 175 and 250 engines that I have in pieces at the moment and they return straight onto the cases.
Chris
ajleone
Post by ajleone »
Hi Pete - No, I have not, probably will.
Chris, you are correct it is a very early 5-speed.
Tony
74 450 MK3
65 125 Bronco
Chris Bushell
Tony,
I may have one in one of my odds & sods boxes of spares, but wont be able to search until after the weekend. Will let you know.
Chris
ajleone
Post by ajleone »
Thanks Chris !!
Tony
74 450 MK3
65 125 Bronco
Italic
Re: early narrowcase 250 segment locking plate needed
Post by Italic »
All this time later, and I need one too! Da same ting!! Mines a 66 250 5 speed, and that little segment locking plate is holding me up! Pete >:|!!!
Awareness can be frustrating
Eldert
Post by Eldert »
Ebay seller gio655 has them for sure .
Eldert
