Below are some notes I have been saving in regard to some various paint codes.......
If you have anything current you can add please do so....
Here are the Silver codes I have so far:
Per Hans Mercedes Benz Astral Silver, Metallic
Per Barbers Dairy resto shop: Dupont D8806 or 95 Ford Silver
Per Syds Cycle: Dupont N8075U Metallic Silver
Per Phil @ Road and Race: Ford Artic Silver
Per Romanelli: Volvo Silver
From Phil at Road and Race
HEY STEVE please adjust listing the ford arctic silver & blue i quoted is for n/c singles NOT twins. the blue is close to kingfisher blue
Peter Koren [[email protected]]
'75 900SS is Fiat F 620 Chairo.
john watrous [[email protected]]
Here's a couple of factory color codes for the early squarecase SS:
sviloid metallizatto smalto alla alluminio #62011 (frame & cycle parts)
sviloid perlato azzurro #62235 (fairing)
I actually have a can of each, the blue metallic is full (.5 L), the silver
(1 L) has been reduced with thinner from a prior tank repaint. Got them from Berliner (US importer) in about 1978. The cans are labelled as being
produced by The International Paint Co. Ltd., Courtaulds Group (London) and also The Societa' Vernici Italianne Standard. I am guessing they were
produced in Italy. They are no longer in business, at least under those
names. Spent some time on the net trying to track them down. They are a perfect match for my '77 900SS. My Imola tank silver is the same, so good back to '74.
Hans Mellberg [[email protected]]
On factory colors. There will be controversy on the green frame. The official color stated on 9 May 1973 on the 750SS parts list is "azzuro metallizzato" and "alluminio metallizzato" for the silver. The problem is that azzuro is the name for blue and not green. When the parts list was created, the 72 Smart and the show bike WERE BLUE and NOT Green. During the later part of 73 the color changed but the litterature did not.
So, we are going to have a lot of people calling the green azzuro when it is not. But, the original Show bike was blue. And, maybe the Smart bike too!!
Here are the color mixes; Dupont Imron Greenframe Green To make a quart:
758S Drier 44.4
700A White 45.3
752A Trans. Oxide 61.3
720A Phthalo Blu II 84.0
742A Blue Green 119.2
710A Med. Alum. 777.8
756A Binder 888.0
Silver
Dupont Imron 42654U
1972 Mercedes Benz Code DB735 Astral Silver Metalic B/C
To make a quart:
535U Jet Black 42.5
521U Alum. 166.5
572U Clear 701.5
Here are some more codes from Steve Ross:
Greenframe: Ditzler DDL 2168
Silver: Ditzler DDL 2518
misc paint codes FAQ
Darmah Black
Anyone nout there able to advise me what colour black is? In particular, the black on my 1980 Darmah.
Kind regards, Mark
Kind regards, Mark
Silver Shotguns: Paint Matching Using Ford Colour Range
(Edited extract from post on Bevelheads List 23/03/2004 by Phil Hitchcock)
Shotguns: Ford Arctic Blue & Arctic Silver from the 80s are close
to older kingfisher colours. Use them as a starting point, then adjust
using tints to suit.
Get a jar of #2 metal flakes from Spray Chief or similar supplier. This
is mixed in the clear top coat over a silver base.
I have seen some Silver Shots that even have small bits of black flake
in them. Almost impossible to match original as you will need spots on the
tank where it appears there was a blob of to much flake - caused
by a blocked nozzle clearing itself!
Don't forget to use a really cheap, almost satin finish, black if you want
to get that factory finish on the frame.
_________________________
phil hitchcock
road & race m/c engineering
2 bon mace close
berkeley vale nsw 2261
australia
fax/ph 61 243884211
http://www.roadandrace.com.au
[email protected]
__________________________
phil hitchcock
2 bon mace close
australia
fax/ph 61 243884211
[email protected]
silver shotgun.........
as a painter, I would go into my local professional paint shop supplier and tell them I needed a half pint of 'bass boat' silver metal flake...... You know, to get that bass boat sparkle!
Metal flake comes in many different sizes, literally. The smallest sizes mimic a pearl paint, but that is a different subject completely.
You should start by spraying down a nice silver metalic then mix up some of those largest silver flakes into your clearcoat as per the manuf instructions and apply. Don;t overdo it and put too thick a coat on. Remember, the original crap paint had these HUGE particles, with space between them... Some other colours as well [the occasional black specs].
750GT gold paint code
---------- Forwarded message ----------
OK, here's the gold paint code I used on Ed's GT and my bitsa. Tom
Paint code is OEM YR529P PPG Deltron 2000 DBC 5807K Sunbake gold pearl That's the gold color.
https://picasaweb.google.com/1100164742 ... DoneAlmost picture ofn George Betzhold's bike
Monza Jr paint codes
Would Ford Arctic Silver be right for a 66 Monza Jr.??
From Carl Dreher...........
here is the info from the paint can used on my newly restored 'orange' 750GT:
Nissan Brand Code: 903272
Main Layer: 903272
OEM Code A2
Description: Imperial Orange, Volcanic Orange Price Code: Z Mixing Scheme: DELTRON 2000 (DBC) VOC Reg 5.92 lbs/gal
Variant: PRIME
MSDS DBC1
Main Layer: 903272
OEM Code A2
Variant: PRIME
MSDS DBC1
Re Road and Race Arctic Blue paint for mach1 s 200ss etc.
I have just got a close match to some scraps of paint and photos I have of these bikes and am fairly sure the closest Euro color is as follows.
European color paint reference:
Derbi Motor 1980 - 2003
Code AKZO: DER9022
Groupe: Bleu
Colormap: 618B6
I have more info if anyone needs it.
I have no way of looking at a Ford Arctic Blue form Australia..
Code AKZO: DER9022
Groupe: Bleu
Colormap: 618B6
1959 200 Elite under Construction
another from Carl Dreher
If you are talking about the orangey-gold color, try:
Deltron 2000 basecoat
Nissan brand code 903272
OEM code A12
Imperial Orange / Volcanic Orange
This is what my painter used on my bike and it perfectly matched an original fender.
OEM code A12
- Diana
Re: misc paint codes FAQ
Hiya,
Can anyone help me out with a suggestion of paint to refinish the gold brembo FO8's on my 1979 900 Replica please?
Cheers.
Stuart
Cheers.
Stuart
Can any supply a Ducati red paint code for my 860? It will have white background to tank decals.
Looking to paint my SS1 Dellorto carb. It was silver does anyone know if the Dupont 8806 listed in this thread is a close match? Don't think it was metallic.
Thanks.
Jeff
Thanks.
Jeff
Jholeman
1966 & 1968 Ducati Diana 250 Mark III
2006 Ducati ST3
2006 KTM 525EXC
2006 Ducati ST3
2006 KTM 525EXC
Does anyone have the paint codes for the Red/Wine colored 74-75 GT's? The paint on mine is pretty much gone, and I can see the steel on the top of the tank.
In My Garage I feel safe No one cares about my ways.
75 GT750
95 900SS
This space that was reserved for a 15 Scrambler Full Throttle is now occupied by a 13 Multistrada
73 CB450t
50 Ford Tudor
75 GT750
95 900SS
73 CB450t
50 Ford Tudor
