Primary gear alignment.
andybaggies
Post by andybaggies » Sat Mar 16, 2019 1:09 pm
As per the title is there a recommended alignment of the primary gears?
By alignment I mean should the primary gear be sitting bang in the middle of the clutch basket gear, or is it allowed to be a little further back as it presently is on mine? i.e
Oh r's I can't even draw a basic diagram in a post, ahem, so give me a moment or two....
Andy B
Re: Primary gear alignment.
Post by wdietz186 » Tue Mar 19, 2019 7:27 am
The gears should be pretty well lined up, the engine gear is fixed due to being mounted on a taper. There should be a thickish washer behind the clutch basket, between the case bearing and the bearings in the basket. You might have an issue with the bearings in the basket. There should be a spacer between them and I think there is a circlip retaining them. If I remember correctly there was a production change in the bearings noted in the parts book. It has been a very long time since I looked at my bike but I think mine were mis aligned by a few mm's but there was no unusual noise or wear evident.
Cagiva Gran Canyon
Post by Craig in France » Wed Mar 20, 2019 1:01 am
When I noticed something similar on my 450, Nigel Lacey told me to stop worrying ... ;)
andybaggies
Post by andybaggies » Wed Mar 20, 2019 11:40 am
Just popped out and measured and the clutch gear is ~1.5mm proud of the primary gear. And from what I can remember there was no unusual noises when it was last running.
I'm putting in a sachse ignition system & as I'm in there I might as well whip the basket out just to check nothing is awry. A quick check of the gear selector spring thingumybob wouldn't be out of order either.
Which of course makes me think I should really do a proper job & check the starter sprag bearing as well.... Even though it feels ok.
We can't be doing that with a Ducati can we :?
Many thanks guys :)
Post by 81mhr900ss » Fri Mar 22, 2019 7:59 pm
I just looked at mine, and estimate the clutch gear to be the same as andybaggies' about 1.5mm proud of the primary gear.
Cagiva Gran Canyon
Post by Craig in France » Sat Mar 23, 2019 12:55 am
Andy, my advice would be to DEFINITELY change the gear return spring, regardless of what it looks like. Just make sure you get one from a reliable supplier (preferably a better supplier than the one Ducati used ... :-D :doh: )
And me, I'd change the sprag as well ;)
andybaggies
Post by andybaggies » Mon Mar 25, 2019 11:32 am
Thanks for the confirmation. Taking the clutch drum off at the weekend showed the 4.8mm spacer was fitted but no extra shims. All looks clean so I'm happy with that :)
I think i'll take your advice on this - I'll see if Lacey have one & if not Ducati Classics in Holland or Mdina should sort me out.
Well when I was assembling & farting about with a puller adaptor I had made up years ago I remembered that this was the last job I did on the old girl - replacing the sprag. But, for a variety of reasons, it was never actual used in anger. So as I don't like removing the flywheel, too much biffing and force for me :~, I'm gonna leave it as is :oops:
But even at hand speed it does catch & release as it should and there should be no more kick backs with the new all singing dancing ignition system - yeah, I know, I know.
