860GT intake manifold: stuck
rjk40
Post by rjk40 » Sat Feb 24, 2018 2:17 pm
Gentlemen:
Whilst awaiting the rework of rockers and cam, I am cleaning up various bits, and am trying without success to separate the carb and intake manifold.
The coupling ring, with screw and nut removed, does not move.
I am guessing that the reducer fitting has become bonded to the carb, but without being able to get the durned thing to move, I am stymied.
If this is another typical Kroil-and-wait deal, then I understand. If these things are not separable without damage, I will move on without separating them.
As always, any advice is welcome.
Richard
rjk40
Re: 860GT intake manifold: stuck
Post by rjk40 » Sat Feb 24, 2018 2:35 pm
Got the clamp to move; stupid me, I didn't think to spread slightly.
Still, the spacer/reducer will still not move; maybe I should just work elsewhere.
Comments?
Post by wdietz186 » Sat Feb 24, 2018 4:30 pm
Try using a heat gun [or hair dryer] on it and get it really warm. Some gentle tapping around the flange might help too, but be careful the metal is pretty thin there. A twist and yank usually does it.
Cagiva Gran Canyon
Post by Craig in France » Sun Feb 25, 2018 5:40 am
Comments?
These two pieces, Richard? If so:
Yes, they do get stuck firmly together - it's not just you! - and you're right to proceed carefully. So as Bill said, a bit of heat and a soak in whatever easing oil/lube you have, gently twist back and forward, take yer time ...
The plastic/nylon insulator ring thingy (that's what it is, btw) will often stay stuck inside the carb.
rjk40
Post by rjk40 » Sun Feb 25, 2018 6:57 am
Gentlemen:
Thanks to you both. I shall do as recommended.
Last question here, hopefully:
Can the collar/ring, Ducati part number 0755.27.527 be spread enough to go over the lip on the carb without damaging it? It doesn't seem to be designed for much spreading.
Best Regards to all,
Richard
Post by BevHevSteve » Sun Feb 25, 2018 11:54 am
Yes the clamp can be removed from the body just use a large screwdriver to twist and remove and yes its barbaric doing so but not impossible - Also I suggest you bolt intake to head then try to twist (only) the carb to remove it from intake manifold. If you really cant get seperated dont worry about it just take everything else off the carb so you can do your ultrasonic cleaning etc and rebuild. Whatever you do - do NOT wiggle wobble the carb trying to remove it as you will crack the body.
Cagiva Gran Canyon
Post by Craig in France » Mon Feb 26, 2018 4:48 am
All as Steve's reply, Richard :)
(Thanks Steve!)
