Sidestand hitting header
OZHoppo
Post by OZHoppo » Fri Oct 14, 2016 1:07 am
Gurus,
I am rebuilding an 82 Darmah which has a Staintune exhaust fitted.
The header hits the side stand pivot point and won't retract fully.
Is there a difference in header pipes between SS and Darmah?
Steve
Re: Sidestand hitting header
Post by BevHevSteve » Fri Oct 14, 2016 11:06 am
yes, but, you said you have a Staintune exhaust fitted..........
Have you already tried loosening everything up on your exhaust and moving the header to get clearance and then tighten everything back up?
OZHoppo
Post by OZHoppo » Sat Oct 15, 2016 1:51 am
Yep, tried that but will go back and start again. I could very well be doing something silly
OZHoppo
Post by OZHoppo » Sun Oct 16, 2016 1:56 am
Problem solved kinda.
I took the exhaust assembly apart to start again and noticed that it has S2 stamped on the pipes. I am guessing that the S2 system is just slightly different from the Darmah.
