Darmah clutch pack
Darmah clutch pack
I am repacing my clutch pack on my darmah. Does anyone know the wear limits on the friction and steel plates? Also, why is the first friction plate spot welded to the inside of the pressure plate? How are you to replace this...chisel the spot welds off?
Darmah Clutch
The one in the clutch drum stays there, just fit up a sureflex clutch kit, all you need is in the kit.
Darmah Clutch
Yes mine was lifting crooked a swell, I just kept swapping springs about until i got it to lift evenly.....maybe someone else has a better solution.....hopefully.
Darmah Clutch
Seacoast69, if you were referring to me when you used the word cheapskate, I think you owe me an apology as you do not know me in any shape or form and I dont think there is a place for you on this forum........it has 6 new springs in it, I swapped them around as there may well be a mismatch in machining heights of the clutch assembly. By the way the female in my life is my wife, I do not degrade her by simply referring to her as my girl.
- BLABBERMOUTH
I'm picking on my friend Mike, if I insulted you or anyone else I apologize. I' have been helping him with his bike from the beginiing and every time there is a slight problem he over reacts. I was just filling in some of the detail he is leaving out that may help everyone understand whats going on and help find his cure. The clutch does fully disengage just cocked. He thinks this will cause a vibration. He has been putting allot of money into this bike and it never seems to ends, but the springs are a little expense compared to headwork, pistons, tank, seat pan, etc. that he has bought, it's getting down to the nitty gritty and so close to being done.
Mike: Start selling some of those spares and build you repair funds, I'm sure there are Darmah people needing parts that you have ?
