SKF Sprag bearing
enforcer
SKF Sprag bearing
Post by enforcer » Sat Jul 20, 2013 6:26 am
Hey there
Im looking into replacing the sprag bearing on my Darmah Ive been studying the forum for a few days now . Just wondering how hard it is to replace the bearing and if the SKF bearing works any better. Any info or feed back would be great .
Jez
rwhc80
Re: SKF Sprag bearing
Post by rwhc80 » Mon Jul 29, 2013 6:52 am
G'day Jez,
I am now on the second SKF sprag replacement in my Darmah, and fingers crossed it has shown no signs of failure thus far. Unfortunately, the first one lunched itself after about 12 months, but I suspect that was more an issue with starter and some occasional back firing issues I was having at the time.( Now rectified )
As for the actual job of replacement, not so hard if you have the correct tools, some time and patients.
Given the cost of an original sprag, I would absolutely give the SKF a try.
Rick.
enforcer
Post by enforcer » Wed Jul 31, 2013 6:28 am
thanks for the reply
Ill have to give it a crack ......
enforcer
Post by enforcer » Sat Sep 07, 2013 3:15 pm
Well . not to many dramas for the darmah. just replaced a few seals/gaskets and the sprag, Engine starts first go now.
there was some grease like build up on the original sprag ? may have been the problem as the original sprag bearing didnt look too bad .any way new sprag in now all good.
thanks for the info
Jez
AndyCapp
Post by AndyCapp » Sat Aug 29, 2015 11:11 pm
My SKF 445419 lasted only 12 months and around 50 starts. No obvious sign of wear or damage to the parts the bearing fits into.
RobiD
Post by RobiD » Wed Apr 20, 2016 8:16 pm
Trying to find a supplier of that SKF number 445419.
Every supplier I've contacted say that the number is incorrect.
Can anyone clarify the number and perhaps a bearing service they have bought it from.
Thanks for the help.
David
Cagiva Gran Canyon
Post by Craig in France » Thu Apr 21, 2016 1:02 am
Hi David,
That's the reference number I have, and they're still available here in France.
https://www.123roulement.com/roulement-445419-SKF.php
However:
Frankly, I would advise you to stop looking :shock: . Please just go buy one from Steve. He even has them on promo at the moment, making them cheaper than I can buy one here.
And that way you will be supporting one of the guys who supports us :-D !
https://store.bevelheaven.com/Engine-Re ... g-Bearing/
Other info, just for future reference
1. The size of the bearing is 49.721 x 66.381 x 13.5.
2. I have seen it claimed that the OEM part was made by Borg Warner and is a component in their BWX range. I think it is a 'Disengaging' bearing and therefore would have a reference number of either 133339 and 1310003. If I'm wrong and it is the 'Engaging' type, then the reference is 137222. Go http://www.ringspanncorp.com/en/product ... wheels-bwx
3. I have also seen it claimed that an alternative reference is DC4972 (4C). For more info on this bearing, go (for example):
http://www.flamang.de/produkte/freilaeu ... bauart.pdf
4. You can also use a Rover car bearing, part # 22A716 (if still available). To do so, you need to slightly reduce the OD of the cage.
Post by BevHevSteve » Tue Apr 26, 2016 9:51 am
Thanks Craig, yes I keep them in stock
AndyCapp
Post by AndyCapp » Sun Aug 14, 2016 12:09 pm
Another SKF sprag failure - this time it has damaged both inner & outer races. I guess getting these repaired would be vastly expensive ...
I do have spare starter gear & primary drive from an old engine, but these failures are getting a bit much. Didn't I read somewhere that it's possible to do some machining which would allow the newer/stronger sprag from later bikes to be used ?
Or is there a mod anybody knows which will finally and fully fix this problem ? (Please, no jokes about a kick start ...)
RobiD
Post by RobiD » Tue Oct 11, 2016 3:12 am
Thanks Craig in France.
Been a while since I've been on here and just saw the replies.
Yes, I've bought one from Steve and it's on it's way to Australia.
Thanks for the advice and input.
