SD900 runs rough
Re: SD900 runs rough
I tried for a year to balance my carbs. Couldn't do it. Rebuilt the carbs. Things got much better, but there was still a hiccup in the idle. When I replaced the insulators, and rebalanced, it went away. Try balancing first, it costs nothing and at worst will rule out the simplest solution. If you bleed Ducati (like Steve ) you can do it by sound. The ghost of my mechanical engineer father forced me to use gauges.
glad you got er done. Time is money though, so all the things experimented with then the TIME spent rebalancing, I mean, attempting to rebalance the carbies has the be factored in.... Bottom line is you got it running right ultimately which IS the goal afterall, right <>
G'day mate,
I am in Mackay. Heading through Rocky in a week's time and will be in Happy Rocks for a week then heading back.
Give me a yell if you need a hand.
[email protected]
[email protected]
RAD
G'day Rad
Ahhh, beautiful Mackay..wished I lived up there, too hot here1
Great to hear you're coming my way. I've sent you an email just a minute ago
cheers
Mozz
cheers
Mozz
.......and credit where credit is due.........Rich Lambrechts truly sorted my bike.
G'day all,
Managed to get Mozz's bike up and running but it was an absolute battle.
Forget the "just strip and rebuild the carbys" approach!!!!!
Almost took a bloody engine rebuild in the end.
When I get time, I will document and describe the litany of cock-ups with the bike that had me tearing my hair out.
In the end, the carbys were a minor problem that only required a clean and new bits. Tuning took about 10 minutes.
Took days to fix the rest.
RAD
