Valve Guide wear.
Valve Guide wear.
Guide wear is apparently an issue with these motors, I am considering a change to cast iron guides and chrome stem valves, any one with any thoughts on the subject?.
- Parallel Twin
- Parallel Twin
- Parallel Twin
You need to fit some good quality silicon/bronze guides not the recycled butter type that Ducati supplied. Here in the states a company named Kibblewhite Precision make an excellent guide and valves to go with them but I don't know if anyone in the UK carries them. Something from air cooled Porsches might be adaptable if you have access to a lathe or a patient machinist friend.
Cast iron barely needs any lube at all, I think bronze is favoured as its easy to machine and more forgiving if a valve is hit.I understand that the cast/chrome combination is hardwearing , I dont think the head was designed for adjusters ,maybe shim type rockers would give better action.Iron guides will also need a tighter fit in the head.I only intend to build this motor once so i'm hoping to cover all the weak points.Hi Ray, glad i'm not the only one who F----ks up the posts!!.How does one delete???.
Bob, The purchase area in the head for the guide is pretty small and I think problems might arise due to expansion rate differences. I've had Kibblewhite guides in my 750 GT for about 20k mi. and last I checked the wear isn't noticable. The originals lasted about 4k. The inherent problem with the guides is they are really too short for proper support and the spring engines wear them more quickly I guess because of oscillations and side loads being greater than in the desmos. Properly set up I think you will be ok with good quality bronze guides.
We will see!! , other classics i built are still up and running after 20 years light use , I have to agree that bevels are needy beasts, however the weak points are well known and these bikes are cosseted and not abused ,my 250 took ages to sort out all the problems caused by others mistakes but now starts and goes like a rocket , Rita ignition, good oil, carefull use and crossed fingers!!.
As a Duc owner of some 32 years I don't see anything at all wrong or funny with Bob's approach to researching options, particulary to adding to engine life using newer technology. Improvements in metallurgy alone are good reason to use a modern bottom end as opposed to an original Ducati part, for example. These engines are expensive to rebuild. If the service life might be extended, surely that's worth thinking about?good luck on that one LOL that so funny hahahahha best joke Ive heard in a long while.
The approach of innovatingly eliminating the factory weak points and improvement of inital factory engineering are two of the key factors that led to Phil Schilling and Cook Neilson's privateer triumph at Daytona in 1977.
'nuff said, I reckon.
My SS has never been apart and I've only ever taken one cylinder head off because of my own foolishness. In all, for a bike that gets used every year, I've had very few problems in my 26 years of ownership.
It probably is time for new valve seals and possibly guides though. Its drooling a bit through the exhaust port and the oil level is dropping more quickly than I like to see.
- Steve Foster
- Parallel Twin
Doesn't look like they have a UK distributor. See:Here in the states a company named Kibblewhite Precision make an excellent guide and valves to go with them but I don't know if anyone in the UK carries them.
http://www.kpmivalvetrain.com/distribut ... ocator_top
I'm now interested in getting some of the Kibblewhite 750 GT guides myself. See (copy the link as I can't seem to get the last bit included in the URL):
http://valvetrain.kpmivalvetrain.com/vi ... |1065|1066
The Kibblewhite catalogue shows no difference between intake and exhaust guides for the 750 GT, but the factory parts catalogue gives different numbers for intake (0755.92.393 standard size for later engines) and exhaust (0755.92.413). (Same part numbers for the 860 GT.)
Based on wdietz186's positive experience with the Kibblewhite guides I assume that any difference between the intake and exhaust guides is insignificant, but I'm curious to know why there are different parts listed in the factory catalogue. Can anyone shed some light on this?
Thanks,
Steve.
- Parallel Twin
Changing the subject just a bit,here is a related suggestion: whatever guides are used,paint a sealant into/onto the guide-rocker box juction of the guide bore. I have seen well built engines suck oil down the outside of the guide bores and smoke like crazy.(Easy to fix,once you find the cause,but a pain in the butt..) The short guide bore of the Ducati is quite prone to this,as is any engine which has had the guide removed by coarse methods.
