G,day Guys, could do with some suggestions here for a Bosch squarecase engine issue.
The bike started destroying plugs some time ago on the front cylinder, every 50 kms or so. originally thought it was fouling the plug but now realise it is burning them out, as the recently re-chromed header pipe is now badly blued for 300 mm from the head. rear pipe is still perfect.
So far remedies have been, 40mm carbs off and cleaned twice, ( 145 Mains 65 Idle ) timing checked, heads off, new exhaust guides, seals ect, re-shimmed, and vavles lapped in. Thought when we took the heads off the burnt exhaust valve was the problem, compression was 70 psi in front 145 rear. Now realise it was a sympton not the cause.
any ideas ?? cheers Rick
Burnt Plugs
Burnt Plugs
- BANNED
Rick
Before I read the entire post I was going to reply when the blue pipe was mentioned , you are running way to lean hence the extra heat turning the header blue , the rest of your post states you have burned a valve , valves only burn out due to a lean mixture or incorrect valve adjustment (shims) to tight
Who did the shimming ?
Who tuned the carbs for you?
Have a read of this , it will put you on the right spot with tuning the carbs or get them done by a pro
http://www.bevelheaven.com/~BB/phpBB2/v ... c.php?t=10
Cheers Marty
Cheers Marty
Thanks Marty,
I think its a given the front cylinder is lean, but trying to start with most obvious reason for that ? I guess a process of elimination, and given the extent of knowledge out there on these old bikes, surely this has happened to a few others. As for the shims, we did them so I know their ok, and besides, the problem existed before the heads were removed and re-shimmed.
Would the tip be to start by looking at the carbs again ??
Rick
Rick
- BANNED
My friend rode a 350 Ducati with petrol from Shell called V-power.Martin Mille / SSD wrote:The only thing left then is the carbs , are you running any valve saver additive with your fuel at all. ? try adding some upper cylinder lube to help cool the valves
Cheers Marty
His Duke was wrecked 2 times before hi noticed that the rubber on the valve in the carb had melted. Hope that this hasn't happened to you.
Best regards
- Diana
Rick, In your carb cleaning did you happen to check the float level? If it is too low it can cause the mixture to go lean at crusing speeds and will seem to go flat when accelerating hard. Also inspect the screen under the inlet fitting and make sure the petcocks flow ok.Another thought,Did the exhaust seat require much cutting to get a good seat?It is possible the seat is warping when hot causing the valve to burn.There isn't much meat around the seat on the port floor and they can loosen/warp when they get too hot.And you are sure you don't have any vacuum leaks right?
Thanks Guys,
In order, Marty-, Not using valve saver as yet.
Hedton-, Just premium fuel, normally BP. 95 octane. we have the same issue with Shell Optimax not recommended for bikes.
Bevel Dave - Checked Advance, no problem there.
Wdietz186- Float Levels have been checked and are OK, seats had a bit of cutting due to new guides, but I beleive they should be OK, ( Will keep in mind though) Vacuum leaks worth checking, but new o-rings went into inlet spacers ( alloy type ) Fuel flow I have not checked, damn good advice that's next on the list.
Excellent feedback, thanks all, I will let you know how it goes.
Cheers Rick.
Cheers Rick.
- Diana
Has the engine been detonating at all? Has it pinged, rattled or knocked under load, especially in top gear roll ons? I ask these questions because the plug condition that you describe can be the result of a moderate to severe detonation problem. Have you used a stobe light on your engine to check the timing on each cylinder? Is your engine modified e.g. high compression pistons, modified combustion chambers?
This is just another angle to investigate and if nothing else it is food for thought.
Thanks again guys
In order, Bevel Dave- Needle is a K4, set on centre slot, 145 jet
Paulh - No evidence of detonation that we could find, engine pulls like a train with no pinging until plug goes again,then simply runs on 1 cylinder bike is almost standard except for slight port job and yes we used a strobe to check timing advance.
Bobnorton- haven't checked fuel flow yet as wdietz186 suggested, but I hope to do tonight. I will check cap venting at the same time thanks.
Will advise on outcome
Rick
Rick
OK, we may finally be getting some where,
Checked the fuel flow from the SS taps tonight and it appeared a little slow. I decided to do a comparison with my Darmah, and ran this test : The Darmah filled a 200 mls jar in 20 seconds.
The tap to rear cyclinder on the SS put 60mls in the jar in 20 seconds and the tap to the front cylinder put approx 90 mls in the jar.
Not sure what the flow rate should be, but I assume it indicates some sort of problem ? I guess at this stage it's not a definite until I get the taps removed and check them out.
again will keep you all informed,
Cheers Rick
Cheers Rick
- BANNED
Rick
With that flow rate one would think that the rear cylinder would be running hot, less fuel - Lean running
Back to basics
Timing might be fine but an ignition box could be failing under load changing your advance curve giving you a leaner burn
Are you sure that you are not sucking AIR as this is the usual culprit for burning valves
Marty
Back to basics
Marty
Hi Rick,rwhc80 wrote: I decided to do a comparison with my Darmah ...
If you've also got a Dramah, can you not just temporarily put the front carb from the Dramah on to the SS and see if the problem persists?
That way, you'd at least know whether it was the carb that was faulty - or something else.
P.s Or swap the ignition box to test that ...?
