Hello folks !
The throttle handle travel of my Darmah is not enough to open the 40 mm carbs the full way. The (Nippon Denso) handle was originally made to move the 32 mm carbs.
Any suggestion how to get more travel ? O.K. - I could purchase a Velicchi or Tomaselli handle / grip, but may be there is a Nippon Denso part from some japanese bike I can use instead !?
Joe
Daramh - Travel of throttle handle
You are in doubt ?......ask a Kraut ;-)
Cheers from Germany
(Ducati 900 SD, Suzuki GSX-R 1000 K6, Suzuki GSX 1200 Inazuma)
Cheers from Germany
- SSD900 Darmah
My dirtbike has an adjustable throttle cam. It is a simple swap out of the ramp in which the throttle cable travels on , on the end of the tube. Its a simple way of changing the feel of the power curve. Maybe you could adapt one to your throttle or figure out a way to increase the diameter of yours so that it would take the same amount of twist to open them all thew way up?
