Does anybody know if the early style primary gear (I think it is from a 1975 860) will fit on the later (1981) bosch ignition style crank? I have a trashed primary gear (cracked) and need to replace it. It appears that all styles of these gears use six allen bolts and two pins so I hope all that I can use the older gear with the later flywheel... (because I can't find a later gear).
Early 860 Primary gear on a late Bosch ignition crank:
- BANNED
