Darmah heads V's SS heads
Gday all, is there a difference between a Darmah head....58mm inlet studs, and a SS head......58mm studs ie camshaft profile or head markings?
SS and Darmah heads the same?
Hi Grover,
As no-one else has yet replied ...:-)
Check the books, especially any of Ian Falloon's; but I'm pretty sure the SS and later Darmah heads are the same.
However, it may be worth pointing out that there were different size valves (and seats) and different cam grinds available from the factory - as well as from others, to be sure, over the years.
HTH Craig in UK/France
