Hi all,
I'm installing new chain and sprockets, and, since I am using new parts from Steve, and have no
experience in the "feel" of the new parts' installation, I respectfully need help on these two things:
1. New 530 o ring chain with clip type master link. The closing side of the master link will not slide, by hand, onto the
link pins far enough to expose the recesses for the clip. Is this normal, and I just need to squeeze the
side piece on with pliers until the recess is exposed? The old link's piece slid on nicely and exposed the recesses
without the need for pressure from pliers.
I have two new clip type master links from Steve, and they both act the same way.
Comments?
2. The new drive sprocket star washer's inner tab is long enough to keep the washer from threading onto the
threaded part of the shaft. The old washer's tab is considerably "shorter", and bent enough to allow the washer to thread
onto the shaft's threads, but has a really sloppy fit into the slot on the shaft once seated.
Do I grind and bend the tab a bit until the washer threads onto the shaft?
Or am I missing something?
Comments?
Thanks in advance for any helpful info.
Richard in Florida
1975 860GT : Two questions
- Paso 750
Re: 1975 860GT : Two questions
Hi Richard,
1. New plates are often/usually a tight-ish fit. Just tap the side plate down over the pins using a little drift - a small socket, for example - and a light hammer. If it seems tighter than that, come back to us.
P.s Simply rotate the wheel until you have the split link supported in a convenient position on the rear sprocket.
And it never hurts to lock-wire the side plate + the fishtail on.
2. Sounds like the lock washer's tab is too long. So just cut it back.
P.s. As I'm sure you appreciate, they're not the greatest way of locking anything on to anything. So don't feel shy of using a dab of Loctite :-). And the nut needs to be tight - 60ft/lb.
Thanks kindly, Craig,
The info really helps, and gives me needed assurance that my curiosity in these areas
is not completely unfounded.
I shall follow recommendations in both areas.
My last experience before this with master links was on my 1969 Norton Commando
in 1974 (loved that bike, even with the Lucas electrics). Good old Isolastic engine mounts.
Not so much fun with the Whitworth threads/wrenches here in the colonies.
Things have changed a bit since then. I agree on the safety-wiring as well,
and will continue with that; inexpensive insurance.
Yeah, the sprocket washer tab , and getting it past the shaft's threads,
is a bit "hokey" (as we say here in the colonies...). I'll just be very careful to not
take off too much meat of the tab. Also, slightly bending the tab toward the engine
might be a good idea, if I can do that without distorting the whole durned washer.
Good thing I bought an extra one.
Richard
Richard
