Clutch noise
Posted: Tue Jan 31, 2012 3:02 am
Hello all. I have a 750GT engine with clutch noise and hope someone can point me to a likely problem before I pull it apart. The clutch works perfectly but when I pull the lever in it's starting to make a bit of noise. My first thought was a thrust bearing or some such thing but on getting a manual out it doesn't seem to have one. It appears to me that the only bearing as such when the clutch is actuated is a pushrod ball. I can't work out what could be working loose if it's something else.
I suspect it's a common thing - any suggestions out there? It's not serously noisy yet but it's noticeable enough to start worrying about the old girl.
Cheers, gabby
Cheers, gabby
