WHICH IDLE JET FOR PHF 32
maxmar
Post by maxmar »
WHICH IDLE JET SHALL I PUT ON MY PHF 32 CARBS FOR DUC 750 GT?
still have this idling problem .
i have 60 IDLING JETS . i found in ian falloon book those carbs where fitted with 70 idling jets.!
idling screw is set to there maximum on both carbs and i only get 800 rpm when bike is hot.
i ve changed the rubber between carb and engine.
thanks
Post by machten »
Pilot jet for a 32 mm PHF Sport and GT setup should be 65.
maxmar
RE
Post by maxmar »
OK THANKS KEV
