Pre Load End Float
jonduc74
Pre Load End Float
Post by jonduc74 » Wed Apr 25, 2007 4:46 am
End Float
I understand that you have to “pre load” a GT750 motor by some thou to bring it in to zero end float when assembled, not sure what is the best amount, could someone help out there.
Also does anyone know if it is possible to remove “end float” from the crank by shimming between the casing and the flywheel, without have to split the cases?
Many Thanks John
jonduc74
Re: End-Float
Post by jonduc74 » Thu Apr 26, 2007 2:57 am
Hi I have also posted this on “Motor & Transmission Shop” Please also look here to view replies,
Jonduc74
