Greetings from Ireland
smellybeard
Post by smellybeard »
Hello all.
I’ve had some non-runners in the shed for decades and they are finally reaching the top of the the to-do list. Mostly 250 singles - a narrowcase bitsa and a couple of widecases.
First up, however, will be a 1981 Pantah 500 - a bitsa with some interesting bits.
It's been unused for about ten years and was a present from the previous owner who not only was loosing his storage space but was also giving up riding. On opening up the side plastics to check the engine number, I found this...
Forks and wheels are non-standard. Forks are marzochhi adjustables and wheels are five-spoke speedlines. The engine is said to have 600 pots. The previous owner thinks it was built in a UK race shop from leftover bits.
Best of the 250s is a 1975 Mk.3. Alas the big end went after about thirty miles. I didn't waste any breath on the dealer. It was a really nice bike to ride; light with excellent brakes. Imagine a mountain bike with the guts of thirty horsepower. Bevel head cranks are not easy to do so I think I'll just drop it out and send it off. It was a little bit smokey so it might get a set of rings while it's asunder.
Re: Greetings from Ireland
Looks like a 1980 500 (to start with) because it has the oldstyle fairing.
There WAS a defective batch Speedlines, but they were also used on the 500 SD without (as far as I know) breaking.
Better let them xray.
Welcome aboard. Hopefully the carbs (and cylinder head) didn't get filled with rat wee wee.... that would mean everything will need replacing. Good luck with your projects!
