Darmah down under
Converted Duc
Darmah down under
Post by Converted Duc »
Hi all, my love for the Bologna blasters started last century and in that time I have owned two bevels (S2 which became an Alchemy) a 750 Paso, a 888 and recently a 1977 Darmah I intend to restore. The bike has been modified by a previous owner and appears to run strong. The handle bars and SSD style pegs have made way for original items in a quest to make it more comfortable.
Unfortunately I don't have the correct kick starter (mine is the shorter curved GT type) and toes suffer for it, I will find one one day either that or I cut and weld the one I have. Unfortunately it has no starter motor but the case / housing is there so when I source one that will go in. It is currently painted a red / gold combination in the SSd style which is ok and I can live with for now.
Will probably ask a number of silly questions thanks for the add. I think I added the picture ok.
Re: Darmah down under
1977 , Must have a low number then.
Pity about the original wheels and discs but now EBC floaters on the FPS wheels. Nice touch :-D
Starter probably dumped because the starterclutch went bad. Nothing that can't be fixed.
Conti 2-1 ?
Welcome aboard
Gardner
Post by Gardner »
Hi Converted Duc, curious, were foot peg mounts added/welded to the frame to use the SSD set up?
1978 SD Darmah
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
