Greetings. After some 16 years of begging, bugging, cajoling, and coercing, a friend has consented to sell me his 64 Ducati Diana. All manuals and extra parts come with it just as when he bought it in 64.
There is one problem I could use some help with. The kickstarter won't "catch," that is, the pawls don't seem to engage. So one must push start. I have solicited local opinions with some stating the cases must be split with others stating the problem can be addressed within the engine side case.
I know little of Ducatis and to be frank, I don't care to learn. My Moto Guzzis keep me busy. So I seek a suitable repair agency expert in Ducati singles.
Another issue I have is whether this is a narrow or wide case and what difference does that make?
If any one can answer any of the following questions regarding a 64 Diana, I would appreciate it:
1. Is this a narrow or wide case model?
2. Do the cases need to be split to repair a kickstarter not engaging?
3. Is there a Ducati singles repair facility capable of this repair (preferably in the Pacific northwest)?
Thanks for any help you can offer.
About to be the proud owner of a one-owner 64 Diana
- dualguzzis
dualguzzis
73 Moto Guzzi V7 Sport "Sophia"
73 Moto Guzzi Eldorado "Cream Puff" (it's white)
80 Moto Guzzi SP1000
07 Moto Guzzi Norge
and soon, 64 Ducati Diana
07 Moto Guzzi Norge
your bike is a narrow crankcase . if your lucky you dont need to split the
cases only remove the clutchcover . there is a forked leaf spring that
holds the kickstartergear in place . this spring is to weak . sometimes
people put 2 or 3 springs on top of each other .
a better solution is to convert to later type coil spring setup
this coil spring is held in place by a steel bridge that gets bolted on
i know Rich Lambrechts from motofinesse does that conversion
http://motofinesse.com/
Regards Eldert
Regards Eldert
