Hi Ragazzi,
I "heard" that some beavel engines suffer from a bad alignement of piston - piston rod and flywheel. which could eat up the washers between piston rod and flywheel and therefore destroy the needle bearings ... and then you know the story ....
anything worth listening to that story ?
thanks & cheers
--> david
Piston - piston rod- Flywheel alignement - 900 electr. start
- BevelHeaven Sponsors - Supporting Vendors Who Support This Place and You
- ↳ Click here to become a supporting vendor and sell your products
