hi all, can any one help with a problem i pulled my clutch case off on
the weekend and the plates came off,but the splined central basket has
sort of got wear marks on the splines where the tangs of the plate rub.
question one : can i just file out these undulations with fine grade paper
or do i need a new splined centre
question two :how much meat does the clutch need to have on the plate
mine have only got about 1-1.5 mm,is this enough.
thanks
worn clutch ?
worn clutch
hi, bike is 72 gt,
i did try filing down but need a very thin file to get into the groove of the splines,does this not matter about having more play in the splines ?
Re: worn clutch
On the road you won't even notice the difference.co311a wrote:hi, bike is 72 gt,
