Ducati 250 engine compression test
Posted: Sat Dec 01, 2018 11:02 am
by Dukati250
Hello,
I just introduced myself in the above introduction section and posted few pics of my newly acquired 196? Ducati 250 mk3.
My first two questions are:
1) what is a good cylinder compression test figure for the 250 engine?
2) which engine oil should I use?
Thanks to all
Vladimir in Wakefield, MA USA
Re: Ducati 250 engine compression test
Posted: Sat Dec 01, 2018 11:03 am
by Dukati250
Here are some pics
Posted: Sun Dec 02, 2018 5:41 am
by Craig in France
Dukati250 wrote: ↑Sat Dec 01, 2018 11:02 am
Oh, you don't know what kind of a hornet's nest you've just poked your stick into !
Right, I'll say this quick and then run for cover:
1. Are you groovy and modern and want the best for your engine?
Then use a quality 20-50 multigrade, synthetic if you can afford it, dinosaur juice if not.
(I note that Nigel Lacey* sells Silkolene Comp 4, an esther-based synthetic 20-50 which, if it's good enuf for Nigel, is good enuf for me! It's possibly not marketed in the States, but something similar will be.)
2. Or are you a traditionalist who believes nothing has improved in engine oil formulation since 1966?
Then use a straight 40 weight mineral oil.
Which ever you chose, change the oil frequently - as well as the degradation caused by heat and use, you have to get rid of the all the acids and carbon produced by combustion. And also abrasive material coming off of the clutch. Every 1,250 miles was the original recommendation. You can push it a bit more with modern oils. I do mine every 3,000.
http://www.laceyducati.com/ducati-parts/
Posted: Sun Dec 02, 2018 6:21 am
by Dukati250
Thank you Craig for being first to respond!
I will go ahead and use 20/50 syntetic and ofcourse change it regulary.
Any thoughts on the compression test?
Right now I am only getting 65psi but I still need to check valve clearances and make sure there are no leaks...
Posted: Mon Dec 03, 2018 12:16 am
by Craig in France
Dukati250 wrote: ↑Sun Dec 02, 2018 6:21 am
See other thread.
