Tab washer bender tool
rjk40
Post by rjk40 » Thu Jun 21, 2018 3:12 pm
Hi All,
Getting ready to re-mount the timing wheel and gear on the crankshaft on my 860GT, am looking for a source for a good washer bending tool. Most I see on the market are for electrical applications, and I don't believe that they are up to the level of "robustness" necessary on the crankshaft nut tab washer, a pretty stout piece. Most auto suppliers don't show this tool, not often seen by most customers.
Any recommendations are appreciated.
Thanks in advance.
Richard Kovach
Malabar, Florida USA
Cagiva Gran Canyon
Re: Tab washer bender tool
Post by Craig in France » Fri Jun 22, 2018 4:06 am
Hi Richard,
See what others say, but ...
I know that Tony Brancato uses a par of vise grip (mole grip) pliers to fold up tab washers. Saw him do it once, and have since done the same myself.
All you need to do is to start the bend using a lever - a screwdriver for example. And then using an appropriately sized and adjusted set of vice grips, put one jaw under the washer, the other against the nut on the opposite side, and squeeze the handles together to complete the bend.
Done carefully, this brings the tab up nice evenly and tight against the nut - and no need to bash away with a hammer and drift.
rjk40
Post by rjk40 » Fri Jun 22, 2018 6:18 am
Yeah,
Thanks, Craig,
That idea had popped up in the cobwebs of my brain as well.
I was just trying to avoid putting a lot of torque on the facet of the nut, since the bending tools I have seen have a "pin" that centers on the shaft that the nut is screwed onto, thereby avoiding said torque.
But, I'll heed your good advice.
Best Regards,
Richard
Post by wdietz186 » Fri Jun 22, 2018 4:56 pm
I start by bending the tab slightly 180 deg. from the locating tab and usually use a pair of Channel Lock type pliers to pull it up to the flat on the nut after torquing.
rjk40
Post by rjk40 » Fri Jun 22, 2018 6:48 pm
Got it; thank you.
Tried both my channel locks and one of my Vise Grips, and they will both fit, so that's a relief.
Richard
Post by ducadini » Tue Jun 26, 2018 8:22 am
Just imagine this : how would Guido have done it in the 70s ?
Still searching after the pistonpinringfittingtool as steen in one of the 80s Ducati movie.
Ducadini
rjk40
Post by rjk40 » Tue Jun 26, 2018 9:04 am
Yeah, Guido would either have done it with his bare hands, or have had a hired hand who would have done so.
As for your other comment, I found the ultimate bore-specific fitting tool from Summit Racing; if you want details, please let me know, and I will gather the info and send it to you. Price was $38. U.S. plus shipping from Ohio U.S.
Richard
Post by ducadini » Sat Jun 30, 2018 3:14 am
Hey Richard,
Yes, still looking for it (didn't find it but up in the Alps my internet isn't on Duc-speed :shock: ).
Mind You : it is a tool where You fit the pistonpinclip on and then just push it in the piston.
No fuss with pliers, screwdrivers and rags pushed in the crankcase and SILENCE in the garage (so you can hear them drop).
Thank You in advance
