Clutch judder
Posted: Mon Aug 15, 2016 12:49 pm
On my 1972 750GT I have clutch judder (slipping & grabbing) when I set off from a standstill.
It feels like the clutch pressure plate is not lifting evenly.
Through the clutch inspection cover I have checked that the clutch spring screws are tight & the clutch pressure plate appears to be lifting evenly.
Could the clutch drum or plates be notched through wear & hanging up on each other, causing the problem?
Time to take the primary cover off for a look.
