Clutch judder
pouchy750
Clutch judder
Post by pouchy750 »
On my 1972 750GT I have clutch judder (slipping & grabbing) when I set off from a standstill.
It feels like the clutch pressure plate is not lifting evenly.
Through the clutch inspection cover I have checked that the clutch spring screws are tight & the clutch pressure plate appears to be lifting evenly.
Could the clutch drum or plates be notched through wear & hanging up on each other, causing the problem?
Time to take the primary cover off for a look.
Re: Clutch judder
yes - have a look there and, make sure the center nut holding the clutch basket on is super tight as well - these have a habit of backing out on lots of bikes it seems......
abmartin
Re: Clutch judder
Post by abmartin »
Both twins I have owned - an 860GT and a 900SS - have done that occasionally and I just came to accept it as normal.
