Tach drive coupling piece detail
Post by BevHevSteve » Thu Nov 15, 2012 3:58 pm
Here are some photos and a spec drawing of that funky little coupler piece inside your tach drive in case you need to make one...
Cagiva Gran Canyon
Re: Tach drive coupling piece detail
Post by Craig in France » Fri Nov 16, 2012 12:57 am
Ah - that's the little piece that likes to fall out and roll under the bench, yes? >:|!!! :doh:
Thanks Steve. Could be useful, hope it never is ... :)
Post by BevHevSteve » Fri Nov 16, 2012 6:13 am
Yes Craig, I bet you can figure out why I needed to make measurements of one then.... So I thought, since I had the info, I might as well post it.
Cagiva Gran Canyon
Post by Craig in France » Fri Nov 16, 2012 9:37 am
BevHevSteve wrote: So I thought, since I had the info, I might as well post it.
Ah, 'The Power of the Web', eh Steve? Good, init? :-D
Post by wdietz186 » Sat Nov 17, 2012 8:52 am
Might want to do the same with the Oldham coupler for the shifter box too! They seem to disappear when things are apart for a while.
radecal
Post by radecal » Mon Nov 19, 2012 4:07 pm
Amen to both bits!!! Amazing what nooks and crannies they can disappear, or rather, fit into!
RAD
