Carbon be gone
Carbon be gone
Anyone have any advice on the best way to clean carbon off piston heads and inside cylinder heads? Is there a good chemical soak on the market?
Re: Carbon be gone
Easy off oven cleaner,Paint Stripper,Permetex gasket remover. All contain Methylene Chloride which removes skin too. Spray or brush on and wait awhile,wipe or rinse[follow directions on container]. Wear gloves and use with good ventilation.Ruins paint too.
Re: Carbon be gone
Also wear a head sock and face shield and safety glasses. Better to be prepared, safe and not get hurt doing so......
Re: Carbon be gone
Good to know. Thanks for the advice, I will heed that. Will I need to polish clean heads with fine steel wool or the like after? Or will that scratch, etc?
Re: Carbon be gone
This post is a little old but this is worth mentioning on this topic. The tale is not about a bike as such but crosses over. I work as a Marine diesel mechanic and recently had an instance of a gentleman who had purchased a small 3 cylinder diesel Yanmar engine in his boat. The engine had done little work but had been left to sit for a long period of time. The engine was very difficult to start and after going through all the checks of fuel and air supply, and since the engine could only be started with Aerostart (ether) or hot air gun in the air intake I deemed the engine had compression issues. As the engine had low hours and had been left to sit for a long time I decided it was most probably the rings had stuck in the grooves(common on marine diesels) and usually the fix was to remove the pistons, clean the grooves and replace the rings(while your in there) and hone the bores.
The owner was low on funds and could not afford this so I suggested spraying a carbon remover down the intake while rolling the engine on the starter but not letting it start and letting it soak for a day. I was not at all hopeful and explained not to get his hopes up as I had never used these "aero fix it`s". Truth be know I frowned on them but this guy was broke and desperate.
No one was more surprised than me at the miraculous recovery of this little engine. Now an easy starter under it`s own compression. I`ve since noted there are many different brands of this stuff around. Some of it recomended to be sprayed down the air intake of petrol engines while running. So if carbon is an issue, or rings are stuck in grooves for the sake of some $15 it`s gotta be worth a try. Won`t fix worn rings, bores or pistons but sure does shift the carbon
