350 timing
raptor
350 timing
Post by raptor »
:? Please any one , how do you ignition time a 350 narrow case using a timing disc ,what do you fasten the disc to , and how does an AMal carb work ( basically )Raptor
Chris Bushell
Post by Chris Bushell »
If you take the blanking plug (14mm hex) off the primary case you can gain access to the end of the crank. This will take an 8mm x 1.25 bolt that you can use to support the timing disc.
