Gearshift change
Davidwood
Gearshift change
Post by Davidwood »
Can anyone tell me how easy it is to change from right hand gearshift to left hand?
Ducati 860
Norton Commando
BSA Starfire
BSA bantams
If your 860 is an early one[not Bosch ign.] it is as easy as replacing the shift spindle in the shifter box. The spindle is from a 750GT and is a direct replacement.I did the conversion on my 77 900SS and had to make some linkage and weld a tab on the brake lever to connect it. Being a rear disc set up all that was needed was to weld a bracket on the other side of the frame and mount the m/cyl. with a shorter hose and a re bent link rod.
A drum rear brake will present some problems but I think it shouldn't be too hard fab up an anchor for a cable and an attachment for the pedal.
