rwhc80
ohm didn't understand you.
I will definitely do that. however i still have this feeling that i will be left with a bucket full of bolts and gears and no idea what to do with it
Darmah Engine Overhaul
the engine vandalism continues...
took off both the heads now, by the way both the pistons look fine to the naked eye, id say the seem to be in sharp condition I don't know why the engine oil smelt like fuel...
took off the clutch plates and there you go, I think that the teeth on the plates seems a bit pointy .. am I right? it also seems that there are some groves on the housing, do I need to replace the housing and the plates?
Hashashan,
From your photo it looks like the inner clutch drum is quite badly notched from the clutch plates. ( It's very common by the way ) But if your going to the trouble of a re-build, then I would source a new, or good 2nd hand inner drum and a new clutch pack.
As the notches get worse, the plates get stuck when trying to engage the clutch and becomes a pain to use.
I have been told that people have filed some of the notches out, but I think that would only be a temporary fix ,as the plate then has even more room to travel, and would hasten the same problem.
Never tried it myself, but maybe one of the others has ????
Rick
Rick
Check your float valve needles and the float levels you could be running rich.hashashan wrote:the engine vandalism continues...
I haven't had direct experience with this but I was also told to ensure I turned the fuel off when parked since it was possible for fuel to drain into the oil sump in particular through the Horizontal cyclinder. If you look at the angle of the front carb if the float needle wasn't closing fully gas could keep draining through it into the engine.
went on vacation and got me some 36mm carbies
now im back to the duke ... took off the clutch basket quite easily, holding it with a screwdriver.
took off the electric ignition stator ... and when i got to the flywheel i encountered a problem ... it just wont go off, no matter what I do.
any suggestions?
any suggestions?
Tapping (understatement) it means putting some akward forces (effectively bending the crank) on the bearing that takes all the driving forces (the rightside) so it could backfire a few (hundred?thousand?) miles further.
Taking the rightside crankcase off isn't an really option, as then you are putting the force on the leftside bearing , not designed to take this and could pop out, and wacking your flywheel against the case.
There is a special puller (sort of a basket) that clamps just the primary gear, try to source it for use. Then wack it :-)
cu
cu
Hello Hashashanhashashan wrote:on what side are you talking about? I tried hitting it on every possible location.
should I hit it hard? im afraid to damage it
I asked a "bevel" mechanic how to remove the fly wheel and he advised to give the fly wheel a sharp hit on the face towards the edge to pop it off the tapper. When I questioned him regarding the ducati puller he said he always uses this technique.
Since I have removed the fly wheel on the Darmah several times using this method.
I understand we should use the proper tools however works for me and the mechanic who does Bevels all day every day.
Strike at your own risk
good luck.
John in Sydney Australia
Darmah 900sd
900ss
Darmah 900sd
900ss
