Oil Leak
Brian Lees
Oil Leak
Post by Brian Lees »
My new aquisition 80 Darmah SS seems to have developed an oil leak in the countershaft area. no doubt from sitting in a barn for the last 10 years. any hints would be greatfully appraciated. I sure hope in not going to have to go inside to put in a new seal.
thanx
ducati automatic chain oiler
easy fix, done outside the motor. 2 different seals, 1 small one just inside the countershaft sprocket in the tube, you can stuff in 2 or 3, the larger one on the outside of the shaft is harder to replace but not too difficult, usually it is the samll one[s]...... I stock both. Clean everything up real well, go for a ride, then look to see where exactly it is leaking from then get back to me to buy the seals.
Cagiva Gran Canyon
Oil leak
And don't forget the Steve Wynne tip - use two nuts and put some silicone on the threads. Working for me ... :-D
duck-a-tye
Post by duck-a-tye »
Hi Craig, are you talking about fitting two sprocket nuts? and silicone instead of loctite on the threads?
Cagiva Gran Canyon
Hi duck-a-tye
Yup, that's it. 2 of the round sprocket nuts, silicone on the threads ...
"If it's good enough for Steve, it's good enuf for me :)"
Craig in UK
duck-a-tye
Thanks Craig,
How's the weather in the UK? must be nearly good enough for riding soon!
