Hi All
Does anyone know what the SSD came out with from the factory in the sprocket department ? 15/36 does that sound about right ?
SSD sprocket ratio
SSD sprocket ratio
Hi Martin,
The owners manual specified 15/36. It wasn't the same as the SD.
And, before you ask: the specified oil was Agip SINT 2000.
Craig (now running away fast ...)
- BANNED
Breather hose
Hi Martin,
Nah, sorry, can't help you with the hose. However, I'm looking out for the plastic bit that sits on top the breather for a mate so, with a bit of luck, might find the whole lot somewhere ...
Will let you know if I do.
