FLYWHEEL PULLER
- BLABBERMOUTH
FLYWHEEL PULLER
DOES ANYONE KNOW WHERE I CAN BORROW OR HIRE A FLYWHEEL PULLER FOR EARLY BEVEL IN ADELAIDE AUSTRALIA
- BANNED
- SSD900 Darmah
Puller
I adapted an old harmonic balancer puller and this worked well. If you lay a peice of paper over the stator and rub/press with dirty fingers you get a bit of a template. Take this down to your nearest bearing supplier/auto parts shop/industrial supplier and see if you can get a puller that will match or can be modified to match. Use caution however as the stator can be on the taper very tight and it is important that the puller has a good grip or damage can result. If your not that mechanically inclined take it to a professional.
- BLABBERMOUTH
puller
thanks for jogging my memory . i remember years ago to replace stator plate i used a universal three legged puller.ithink i replaced the arms with bolts and washers that fitted trough the holes although that seems a bit agricultural
