ssd front sprocket oil leak
oil leaking from front sprocket. have replaced sleeve,both seals( mainshaft and sleeve gear),still leaking.sprocket is tight(not coming loose).after days riding is dripping quite a bit. the seals have been replaced twice. am wondering whether mainshaft damaged where inner seal runs,last resort is to split cases and ain`t to keen on that at moment. any suggestions ?
drip drip drip
I had a similar issue on my GTS. Problem turned out to be the finish on each end of the sealing sleeve that runs in the seal. A close look at one side showed machining marks, the other side was pretty finely lapped. I flipped it over so the lapped side was in toward the crankcases and Bob`s your Mum`s brother. I also put a very, very thin film of Permatex No 3 non hardening sealant on the sealing face. This is some years ago and she`s been fine since. Unfortunatley I went through the rigamarole of replacing the seal, lots of swearing and mopping puddles of oil off the shed floor before I sussed the finish issue. Hope this helps.
drip drip drip
thanks for that,have been using loctite master gasket on sleeve myself but must admit have not been closely looking at sleeve ends.
