UNOBTAINIUM
cafe*racer
SSD900 Darmah
UNOBTAINIUM
Post by cafe*racer »
cafe*racer
SSD900 Darmah
this was someone's bevel hell, not mine. I aquired these with some other parts. any ideas on repair? building back up with weld maybe...Image
1funduc
Rod Rebuild
Post by 1funduc »
Some have bored and fitted a hard insert for the bearing surface.
cafe*racer
SSD900 Darmah
Thanks funduc, I will look into that when I get to the engine. Welcome to the forum, Jordan
I would think repairing those rods would end up costing way too much and result in a weaker rod than a set of good single rib rods. Welding would probably weaken the small end and require straightening and heat treatment. Finding someone competent and most importantly willing to do the repair would be a problem too. Falicon might still do oddball repair work but I think it would take intense begging and many dollars. I would polish them up,Put them on the coffee table,and make up heroic tales about how the engine popped going down the corkscrew in front of Cook Nielson.
Charlie withanS
Post by Charlie withanS »
The direction I would go, make the bore true and square and sent it out to be nitrideed. Nitriding will shrink the bore slightly.
Then do the final dimension adjustment with the pin. It is far easier for a machine shop to select some real nice material in bar stock to make a replacement pin out of better material than was originally in the engine and can move the diameter to get the clearances desired.
Cheers Charlie
If it ain't broke, Modify it.
1974 750 Sport and a dozen other less intriguing bikes.
www.ffmsd.com
jpolde
Bevel Big ebd bearing
Post by jpolde »
I gt a price from alpha bearing to rebuild a set. 285 sterling
cafe*racer
SSD900 Darmah
jpolde, what exactly do they do for that price?
MartinMille BANNED
BANNED
Post by MartinMille BANNED »
cafe*racer
If you are still looking for some rod's have a look at Item 220271422309 are they what you are after ?
cafe*racer
SSD900 Darmah
Martin, Thanks for the tip. I could be wrong, but I do not believe the 900 is interchangable with the 750. Jordan
MartinMille BANNED
BANNED
Bugger , would have been a good buy if you have a bottom end blow out.
cafe*racer
SSD900 Darmah
My bottom end is good, just looking to put a bit of extra spunk in the old GT engine when I get to it.
MartinMille BANNED
BANNED
Hey Jordan there is one at flebay right now Item number: 290259349401
:lol: :lol: :lol:
