76 860 crossover shaft problems, still...
Posted: Wed Jul 17, 2013 12:30 pm
Accidentally posted this in the wrong forum...
alright, this issue has kept this bike off the road for 10 years - quite a shame..
Years ago, I had the bike getting stuck in gear. Took the selector box to Desomto in SF, and they replaced some springs and shimmed the box.
Finally re-installed it, and immediately it jammed.The issue seems to be that the arm on the end of the crossover shaft (with the pin) pops out of the 'box lever with "C"on upshift. box is perfect on the bench though. Have had several talented and bevel knowledge people look at this and can't figure it out. We actually extended the "C" on the arm 1/4", but it popped right out.
So here are my ideas:
Try to find another crossover shaft arm or two to see if I can make some combo work.
Modify arms with joints similar to rearset joints. saw one once, so perhaps it would work.
Convert the thing back to rt foot shift. I found this list of parts needed, and I know the shaft that puts splines on outside of the box (shifting spindle 0608.13.20), and I can work it from there. Here is the list:
brake petal 0795.41.100
footpeg mounting stud 0795.69.020
two circlips (or seegers) 735000.1542
return spring for brake petal. . . 0795.41.030
gear shift lever 0601.13.020
shifting spindle 0608.13.200
Not too concerned about originality, but don't want it to stand out too much. also don't want aggressive rear-sets, I'm keeping the "Grand Touring" positioning for long range comfort.
Thanks in advance!
Tom in SF
Thanks in advance!
Tom in SF
