red hot conti
Posted: Sat Jan 29, 2011 2:45 am
by tony
Hi
My 76 900ss the exhaust pipe at the rear cylinder now glows red hot even at warm up . Is this likely to be ignition timing or carb issues or something else? Any suggestions appreciated
Tony
Posted: Sat Jan 29, 2011 2:49 am
by MartinMille BANNED
When was the last time you replaced the carby rubber spacers ?
Sucking will will cause all sorts of damage, at idle you say never heard of that before
Let us know the outcome
Cheers Marty
Posted: Sat Jan 29, 2011 7:31 am
by tony
Cheers Marty - will give it a burl
Posted: Sat Jan 29, 2011 8:14 am
Something related to carb sync, for sure.
So it could be leaky spacers, something plugged in the carbs or ?
Time to R&R those carbies. I have had this happen to a customer bike after carb rebuild while doing the sync. It was dramatic to say the least. I fired the bike up and was syncing when the customer came by. One of the pipes started glowing..... Took awhile before it stopped while I was fiddling around with the adjustments on the carbies. Yes I was using carb stix and following my own advice.
Posted: Fri Feb 04, 2011 1:40 pm
by BEVEL DAVE
I would be checking the ignition 1st on a early squarecase.
They are the major cause of headaches on most of the early ones.
