Cylinder Head Interchange Question
Flat Ernie
Post by Flat Ernie »
Can you put desmo SD heads on a valve spring GT engine?
mizike77
Post by mizike77 »
Yes
79 Darmah
78 900 GTS
86 F1B
80 SSD
02 Harley FXD
72 H2 750 triple
08 KTM 300XC
Flat Ernie
Can you convert a GT head to SD?
Jon Pegler
Post by Jon Pegler »
Only if you are very proficient in the use of machine tools.
You have to bore a hole for the closing rocker spindle, very accurately.
Even then, the spacing of the inlet manifold studs would preclude fitting 40mm carbs.
In short, the answer is no, unless you have access to a well equipped workshop.
Flat Ernie
Jon Pegler wrote:Only if you are very proficient in the use of machine tools.
Thanks.
Bern
Post by Bern »
It's been done.
http://www.bikeexif.com/ducati-750-sport
I bet it wasn't cheap though.
