Hello
I reconditioned the P08 calipers on my '76 GTS. The calipers are of the 2 bleeder/caliper type. I easliy ( with mighty vac) got all the air out of the left caliper, right one went half ok i.e. the front bleeder easily showed fluid without air but the back bleeder keeps showing bubbles, even after 2 bottles of fluid. I have covered the threads in Teflon tape so I don't think any air will enter the system via the bleader.
I it possible that there is still air left after 2 small bottles of fluid ?
Kind regards
Yannick
Brembo P08
tiney bubbles
Ciao Yannick. You have F08 calipers, not P08. When you rebuilt your calipers, you replaced the Oring between them right? It is possible that the oring is not sitting right in the little cut out area. take your caliper apart again and make sure it is right. remember to put a small amount of the brembo grease on that oring also. have fun
