Elefant 87/8 wiring diagram
If you need technical information or help with your Paso based 2 valve 900 Ducati engine - post your FAQs, comments & questions here.
brian cornford
Post by brian cornford » Sat Mar 18, 2006 5:00 am
Hi. I have just bought an electrex RR51 regulator rectifier to replace the old (unidentified) part - but have no wiring diagram for my elefant 750, which is an early one of unknown age exactly (unregistered grey import secondhand)> It's white and black, mainly, with a kickstart, rectangular headlight and luckyexplorer stickers though I suspect these are later add-ons. Does anybody know where I can get a manual, or at least a copy of the wiring diagram?
I was going to bypass all the old wiring and connect up as the electrex instructions suggest, with 2 wires from the generator, two to the battery, and one to the battery via a warning light. But! the bike has two anonymous boxes between the generator and the regulator/rectifier, mounted either side by the steering head, under the petrol tank.
If anyone has connected up one of these, could they possibly help please?
THanks...brian (UK, Sussex)
brian cornford
re elefant 87/8 wiring diagram
Post by brian cornford » Sat Mar 18, 2006 12:19 pm
Spot the daft mistake . There's always one ............ and it's always me! Doh!
Anyway, I have installed the electrex reg/rect but not tried it out yet.
If anyone knows of a manual or wiring diagram, I'd still be ivery interested though!
Thanks, Brian
Return to “900 Paso Engines > Paso 906/907ie, Elefant, Sport. SS, Monster, ST2”
