MH900e engine / frame numbers
If you need technical information or help with your Paso based 2 valve 900 Ducati engine - post your FAQs, comments & questions here.
aussie_bevel
Post by aussie_bevel » Fri Apr 06, 2007 3:02 am
Hey
Could someone provide the engine / frame number for the MH900e as i am currently looking at buying one. I am a diehard bevelhead but the looks of the Hailwood really push my buttons and i can't get my hands on that data readily as my books are all bevel based
Hope someone can help
8)
Paul
Gomi
Post by Gomi » Sat Apr 07, 2007 2:11 am
Hi!
frame numbers are from ZDM 1LA3N 1B000001 for ths US.
As the engine is a stock 900 supersport, numbers should be ZDM 904 A 2C 000001 type (not sure about that).
these datas are from Ian Falloon standard catalogue of ducati motorcycles.
hope this helps ;)
aussie_bevel
Post by aussie_bevel » Sat Apr 07, 2007 4:14 pm
Thanks for the info, hopefully i won't run into any problems with this bike and it will be another one in the bag :-D
Its gunna fall over eventually, cause it only has 2 wheels.
Return to “900 Paso Engines > Paso 906/907ie, Elefant, Sport. SS, Monster, ST2”
