How can you tell a 4 speed from a 5 speed?
- Mariana
Ive got a couple 250cc motors and a 350cc motor that are disassembled and would like to know how to tell if its a 4 speed or 5 speed tranny? Serial numbers are suspect, so dont want to rely on that. At least one of the motors came out of a scrambler frame (1966?). Thanks
Scott
As you're sitting on the bike, if the DM250 is stamped on the left crankcase half(the clutch side), it was built as a 5 speed, if the DM250 is on the right case, it was built as a 4 speed. The shifter box for a 5 speed has an extra peg- you may be able to feel how many clicks you have, but that would just identify the shifter box internals. The engines must not be completely disassembled or you could count the gears on each shaft.
- Mariana
- Mariana
