I got my '66 Monza Jr project home yesterday and started looking a little more thoroughly at it. The wheels are definitely toast, the front has a small hole rusted through. Fine, a perfect excuse for 17" or 18". Cars use the +1 where you maintain the same outside diameter by going to a shorter sidewall, but I don't think that's the case here. I guess I could go to a larger sprocket if necessary.
I am assuming that 17" would be the better choice so not to diminish already modest acceleration without swapping the sprocket. My bike's stock rims are 16 x 2.25 F and 16 x 1.85 R. There appears to be tons of fender clearance, especially for the 17's.
Can I find some used rims that have the same spoke count and pattern from an Asian bike of the same era? I see lots of them on fleabay. The hubs do seem to be different sizes which would get swapped with the stock ones, but I would assume impacts the spoke length? I saw DesmoDog's project where he did the same upgrade. I would prefer not to sink $400 - $500 in a new set if I can avoid it.
Sorry for the novice question. I know next to nothing about what I am doing.
Monza Jr - 16 wheels to 17 or 18?
- Parallel Twin
Have put a couple of these onto 17" rims and found that it helps the handling no end. Also because of the 17" rim you have a much better choice of tyres. Normally put 2.50 front and 2.75 rear ME22 on.
I think you will find it difficult to get pre-drilled rims off anything else - In UK can get chrome Radielli rims for less than $100 each.
Chris
Chris
- Parallel Twin
