Flywheel pullers??
Nick
Flywheel pullers??
Post by Nick »
Does anyone sell flywheel pullers for the narrow-case singles? And, do the magneto and AC flywheels use the same puller?
bobnorton
Post by bobnorton »
Hi Nick, Puller readily availiable about 20£ but I bieleve two types as threads differ, Laurie sells on E-bay or direct. Really need one, what ign system??.Can you post a foto of flywheel?
Cagiva Gran Canyon
Hi Nick,
(Not sure where you are - 'On da Rock' implies Gibraltar to me, but I'm not sure that's right ... ?) :)
If you're in the States, Steve A. has 'em too - Bevel Heaven, look under 'Tools'.
Like Bob says: 2 sizes, if I remember correctly, 55mm and 62mm. I have a note that says the small size is for up to 1967, the large thereafter. But best check first.
P.s I see that Andy Nienhagen does one with an adaptor ring which means you can use the puller for either size. Go
Andy Nienhagen and select 'Werkzeuge-tools' in the 'Kategorie' drop down box at the top of the page.
Nick
Post by Nick »
Thanks guys.
'Da Rock' refers to Hawaii, and, as you can imagine, mine are the only Duc singles on the Island.
